Boost Gauge fitting/position etc
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Alex_225, Feb 4, 2014.
  1. Ok, well I have my Trophy and I rather fancy a boost gauge but have no idea where to begin. I mean I don't even know how these things are fitted.
    Could I be cheeky and ask for some pics of how you guys have them fitted.
    Also are these mechanical or electric? Any advice would be great. :smile:
  2. You could make a pod like this.
    lee
  3. That looks fantastic!
    I quite like the idea of fitting gauges under the stereo, like in a blanking panel or something like that?
  4. lee is this in your car mate? if so how much u charging to make the pods haha?
  5. On the door, where the adjuster for the wing mirror would be if it wasn't electric.
  6. evlution likes this.
  7. He's lucky enough to be in Spain though, not ever going to be cold enough to make an external temp gauge useful!
  8. So how do you physically fit a boost gauge, not so much location wise in the car but actually connect one up?
    I saw a post on here that you can have an electronic one but also seen ones that connect to a pipe under the bonnet, which makes some sense.
    How easy is it to connect one or other?
  9. Electronic or analog - You connect them in same place :smile: You need to connect to a small pipe which is going to recirc valve (on turbo) or to BOV if You don't have recirculation valve.
    I have gauges in original sunshield of the radio display
    1292262_584148998311096_1574223917_o.jpg 1243361_584148994977763_1614642238_o.jpg
    I made it by myseft and then get flocked :smile:
    47012_489106844481979_1916453224_n.jpg 488106_489365751122755_917983438_n.jpg 375025_525240857535244_1265988160_n.jpg
  10. That looks awesome.
  11. That is superb. Thank you for the info on connecting them up too. :smile:
  12. Ash87
    That second dash pod holder thingy looks awesome, very smart.
  13. no that one isn't in my car now.
    I have this one
    lee
  14. I have mine under the radio using this...
    http://bit.ly/11CXa4k
    The price is £9.99, not £999!
    They look great there and are not in your face.
    Paul
  15. Gray
    Gray RSM Moderator
    Any photos of yours fitted?
  16. This pod holder doesn't fit netly. I try this before I make my own gauges holder in radio display sunshield (using triple gauges pod to builid it :smile: )
  17. I chose this option as I prefer the more OE look.
    The dials match the existing speedo/rev counter with the silver outer ring, blue/white backlight and red needles. There's no cutting or fabrication involved, just remove the plastic tray and insert this dial holder, it really is as simple as that.
    Paul
  18. I was looking into a scangauge 2 and placing it into the dash radio display. Any thoughts on the scangauge?
  19. that's exactly the look I'm after, can you remember where you got the gauges and holder from mate? Cheers
  20. I was looking at getting some gauges in the top display area but think I'd rather have them in the din slot! Would it be possible to put the stereo below the gauges in this arrangement?
  21. The only thing I would say is that if you want them for critical viewing, e.g when on track, then you'll struggle to look down and see them.
  22. Yeah granted. This isnt for track tho, its just to jazz up the interior and ive always wanted a boost gauge!
